John Tanner
New Member
- scunthorpe
I have a wolf turbo arc 250 welder (A09086566) single phase although I have had the welder several years I havent done mutch work with it, even from new I have had to use 4mm welding rods because the amps on the welder can not be reduced, when you turn the control knob on the front of welder anticlockwise (which should reduce the amps to make it possible to use smaller electrodes like 3,2mm and 2,5mm and to weld vertical and overhead) but it does not work and hasent worked from new I know I should have sent the welder back when I got it new but their was an imediate job had to be done and 4mm electrodes done the job, but would like to have it operating the way it should and be able to use smaller electrodes. I would be grateful for any help or assistance to get the welder working the way it should.
Thank you
Thank you
