taycat
- yorks uk
got my clarkson tool cutter-grinder home.
want to use the original switch box if possible.
below is pic of it after removal from column.
pic first then explanation of how it is now.
coming in from top
l1=blue
l2=brown
grn/y to earth
bottom
li=blue running to light
l3=brown running to light
connector block to left of switch at bottom is as follows.
no1 hole empty
no2 hole red wire
no3 hole blue
no4 hole empty
white wire running to earth.
now i assume top wires are from plug and ones to connector block are to motor.
correct?
what size wire do i need to replace it with?
also where do wires go on motor?
its a single phase.
was told all working when brought into club, motor was disconnected when they got it so they could move it.
thanks in advance
coming in from top
l1=blue
l2=brown
grn/y to earth
bottom
no1 hole empty
no2 hole red wire
no3 hole blue
no4 hole empty
correct?
its a single phase.
thanks in advance
