C col Member Messages 3 Apr 28, 2008 #1 TODAY WHEN WELDING STANLES STEEL THE WIRE IS WELDING IT SELF TO THE TIP IM USING ARGON Any help or advice gratefully received!! Thanks guys COLIN
peterd51 happy to be here! Messages 1,593 Apr 29, 2008 #2 Hi, have you tried various settings, ie, turn the power down or the wire speed up? What welder is it please? Do you have any photos of the welds? Regards Peter
M monsterer Member Messages 27 Apr 29, 2008 #3 col said: TODAY WHEN WELDING STANLES STEEL THE WIRE IS WELDING IT SELF TO THE TIP IM USING ARGON Any help or advice gratefully received!! Thanks guys COLIN Click to expand... Not enough wire speed, is my guess. I had the same problem welding allly...
C col Member Messages 3 Apr 29, 2008 #4 It is a Clarke 135te The welds are ok it is when you stop it sticks to the tip I will try turn the power down or the wire speed up Thanks guys colin
peterd51 happy to be here! Messages 1,593 Apr 29, 2008 #5 Hi, you could try moving your hand away from the workpiece and keep the trigger pressed for a very short time so the wire runs out a little... it depends on a few factors, how close the tip is the the weld-pool and wire speed, etc. Regards Peter
Wozzaaah The wizard of woz Staff member Messages 17,535 Apr 29, 2008 #6 Check your wire-feed tension is set correctly, also the torch liner may be knackered and causing resistance, it could even be as simple a fix as fitting a new contact tip. All are simple and cheap to eliminate.
C col Member Messages 3 Apr 30, 2008 #7 turn the power down AND the wire speed up and it work OK Regards COLIN
