brewdexta
The biggest tool in the box
- UK
Now the weather has turned it was only a matter of time before I got condensation on the lathes and mills. The last couple of years I've tried various spray on oils and waxes with varying degrees of success in keeping rust caused by condensation away.
WD40 is next to useless unless you spray it very frequently. Gibbs is a bit better needing less frequent treatment and Bilt Hamber Dynax UC is better still needing just one coat.
Using a dust sheet definitely helps reduce condensation, probably because less damp air moves over the cold metal. NO point trying to use a dehumidifier as I would be dehumidifying Yorkshire.
But they all don't prevent it entirely and where water can pool for any length of time then it gets worse.
I was going to get a small pellet boiler with a built in thermostat but I'm a bit skint so that's for next year.
So this year I am trying high viscosity way oil, the kind used on vertical slides, it has the consistency of phlegm but doesn't take too long to brush on. I have covered the Colchester and Myford lathes both Tom Senior mills and the Warco mill/drill.
It is very sticky so I will have to give them a good clean off in the spring however I have loads of DIY on at the moment so I don't think I will need to use them until then.
