hard wired is wired directly to the unit not a plug-in like a eurotorch . cheers petewhat do you mean when you say a hard wired torch? Does your welder have a euro connector on the front for the torch? If so then any mb15 euro torch will do. If not then you can make any torch fit it, its just a case of getting the wires right
thanks for that will check if the solenoid is in the unit or torch.There are 2 types of hard wired torch, one with the gas solenoid in the torch and the other with the solenoid in the welder itself.
You need to work out which you have to make it simpler to replace.
