Lechlar (29107?) I'd use - just because Langy knows!I've tried all the epoxys over the years and found the Lechlar to be far the best, trouble is people try cheaper even after recommendations then wonder why they get problems.
ohhhhhhhhh spray it wow I have not tried spraying jotun 87 yet what equipment did u use? I would sooner spray it, as it is hard work brushing it onYes I used Jotun 87 as a base layer to fill up a number of pits in the metal. It was recommended by @Dcal. It was strange spraying compared to thinner epoxies but you can get a really good finish straight out of the gun if you persevere!
Bet that was hard work taking that back to bare metal on that polo ? Any more progress?Jotun 87 wintergrade for me applied by brush and left as it is.
its not so bad from a distance but there are brush stokes there and you cant see the welding repairs that are hidden under it, that was in 2018, it was running again later that year. just posted it to show that its just epoxy that I use under my cars, no topcoat and no stonechip.Bet that was hard work taking that back to bare metal on that polo ? Any more progress?
Looks fantastic.
Can I spray this over bare metal to make it waterproof when I leave a car outdoors just asking as normal primers go rustyYes I used Jotun 87 as a base layer to fill up a number of pits in the metal. It was recommended by @Dcal. It was strange spraying compared to thinner epoxies but you can get a really good finish straight out of the gun if you persevere!
Often wondered if it was OK to leave unpainted on the underside of a car. Are you completely bare metalling / de rusting first?its not so bad from a distance but there are brush stokes there and you cant see the welding repairs that are hidden under it, that was in 2018, it was running again later that year. just posted it to show that its just epoxy that I use under my cars, no topcoat and no stonechip.
