yep that would be my go to for that no need to glue it if it is the right bore it will hold in place wellYou can buy o ring cord by the meter at most bearing places
There's two metal parts, a base and a circular side bit. The O ring sits in a groove and makes the tin liquid tight. I would think silicon too, at a push I could make my own.
I have got some big food safe ones, I will be home in an hour or so and will have a look to see what sizes they are..
use silicon ayeThanks.
I can line tins well enough but the O ring makes it easier. It'd need to be food grade and is it possible to glue silicon? I thought one of its properties was that not much stuck to it.
I think EPDM is providing you buy the correct grade, I think it would be cheaper to buy a silicon onerubber is that food safe?
make your own if not!
Homemade Silicone O-rings and Tubing
Homemade Silicone O-rings and Tubing: Make your own O-rings and tubing from silicone! The object in this picture is a homemade submersible camera housing, made possible by the silicone O-rings. (my next instructable will be the camera housing) Quick and dirty explanation: Inje…www.instructables.com
exactly! needs to be good to at least 200 CWhat temperature do you cook cakes at? That has to be a consideration as well as the food-safe bit.
That is a very peculiar website, almost spoof like.
