Or, if you need more and have a lathe, buy a tap like this and make them https://www.ebay.co.uk/itm/28475783...TTmAddvu1hkyQ5kvPefPlZE1kz|tkp:Bk9SR4C0w-upYgOn small quantities of oddball stuff like this you are probably better off lubing up and taking the pain.
Bob
"F.G. Lang" engineer suppliers corner of Clarence Road and Stanley Road, Grays.You could try
Abbot Fasteners In Basildon
or
just round from the bearing shop in grays is another niche supplier of random sizes.
XR USELESS now unfortunately"F.G. Lang" engineer suppliers corner of Clarence Road and Stanley Road, Grays.
Another possible is XR Fastners, Lambs Lane, Rainham, Essex.
If you can find a standard size 9 x 1.25mm nut, file it or get someone to mill it down to 14mm A/F's.Thank you all. I've tried a few scooter places, all out of stock. I will try the one mentioned. Plus Abbott.
Citroen liked to place bolts very close to another part, any bigger than 14mm across the flats and the nuts can't be tightened.
A grade 8.8 bolt should really be matched with a grade 8 nut. This probably means something a bit better than 'ordinary' mild steel. (Maybe something like EN8 ??)If a bolt is 8.8, does that also apply to the nut? If it does, is mild steel suitable or do I need a particular type of steel?
Hello, I have a lathe and milling machine. I can drill and tap 14mm hex bar.
I've tried all the suppliers above, some don't stock, other stock only half nuts.
One company said they couldn't help as their minimum charge was £20. And? What difference does that make. They never did say if they stock them. Never turn down money!
I have always thought they sourced snd supplied only.
Machine Capabilities
In our factory, we have a number of Computer Numerically Controlled (CNC) machines, both fixed head and sliding head lathes. These were purchased brand new from the machine manufacturers. Our current machine stock is the Citizen Miyano BNE 51 BSY, the DMG Mori NLX 1500-500, two of the Star GB SR-20J machines, and a Quicktech TT42.
Having recently moved into much large premises, we have room for further machinery giving us greater capabilities and capacity.
Manufacturing Capabilities
We can manufacture the following products in any materials listed above and any thread type:
Engineering Studs
Captive Screws
Spacers
Washers
Full Nuts
Half Nuts
Dome Nuts
Hexagon Bolts and Setscrews
Socket Cap Head Machine Screws
Socket Countersunk Machine Screws
Socket Button Head Machine Screws
Socket Grub Screws
Slotted Screws
