As a purge gas? No.Would propane be OK ?
As an empty cylinder, yes.
I really can't believe how complicated people make this - cutting while filled with water, purging with gas etc.
Just squirt in some fairly liquid (removing the smell makes one feel safer), brim with water then tip it out and do whatever hot work you want.
and they do, I have the certificateThere can't be anything left in significant quantity to present any real danger, and they're well made - it's not like say a petrol tank which is thin and may go quite pear shaped with a good pop.
I got a foot long flame off one while cutting it, washed out like that. Each to his own method, but Im sticking to my method.
@reb78 You cut it open yet???![]()
Honestly.... Do keep up man.
http://www.mig-welding.co.uk/forum/threads/when-is-a-gas-bottle-safe-to-cut.61685/#post-793904
I have used a car wheel cut off the outer rim and weld the base of the cylinder to the centre of the wheel and it sort of flows to the groundAny suggestions for legs that wouldn't look out of place?
Well I for one am not using my argon at the cost of it !!Purge with your favourite (nearly) inert shielding gas?
.Well I for one am not using my argon at the cost of it !!
