I bought one of these:Bucketbarrow for a fencing project at home.
Very robust and doesn’t twist when you put a proper load in it.
Highly recommend.
Highly recommend.
Tipping trailers are far less physical…..Poo plus urine soaked shavings, mrs Robo is really finicky about keeping the horses bed immaculate, which means more for me to barrow to the muck heap![]()
If you need to do physical work, you need to be fit enough and strong enough to do so.Tipping trailers are far less physical…..
Dump Trailer - Quad Accessories/ATV Accessories for Farm Quads
Innovative agricultural machinery from Blaney Agri. Have a look today to see how our machines will save you time and money, increase profits and make your life easier. Includes alternatives to fail mowers and weed sprayers.www.quad-x.com
If I could afford to pay the boys wages I would. But as I cant I shovel the Sh1t and other bedding etc into a tipping trailer, then once a week make the trip to the current muck heap. Saves pushing a barrow over undulating ground a couple of hundred yards!If you need to do physical work, you need to be fit enough and strong enough to do so.
' Never send a boy to do a mans job'.....
A decrepit old dumper is another option....If I could afford to pay the boys wages I would. But as I cant I shovel the Sh1t and other bedding etc into a tipping trailer, then once a week make the trip to the current muck heap. Saves pushing a barrow over undulating ground a couple of hundred yards!
Also barrows dont last long loading them with a digger!
Thief proof
If thats a link? it doesnt work..Did somebody mention wheelbarrows?
Cheaper and holds more, admittedly a quad would probably struggle with that. My little 19hp tractor can move it but is pulling wheelies doing so.Tipping trailers are far less physical…..
I have one of those too, maybe a bit bigger but in winter when we move most waste bedding and poop. The ground gets chewed up too easily by the tractor. Quad and trailer does far less damage. When we were doing up the barns etc, I was given free use of an old 4wd dumper, guy who owns it, just leaves it where last used till he needs it again. Did a lot of ground damage doing multiple runs loosing the big rubble pile of concrete and stone floors. But was far easier loosing rubble and doing my shed base than the tractor and trailer, plus myMrs was happy driving it. Allowing me to load it!Cheaper and holds more, admittedly a quad would probably struggle with that. My little 19hp tractor can move it but is pulling wheelies doing so.
My JCB barrow was found down the back of my mum's shed when she moved in 12 years ago and was already a fair age . It's continued to live outside for the last 12 years.I usually end up going up,down and across a lot of scaffold boards, so I can't see a two wheel one working very well in that situation.
Cheapy £20 metal chillingtons work well for me - run them until the tyre inevitably cracks or picks up too many punctures and then swap them to a solid wheel - less manovarable but not always flat when you go to use it.
Treated well they should last donkeys years, the galvanised ones last even better.
Store them upwards so they don't sit full of water, oil the axles regularly and don't overload them, always clean them out if using concrete.
I suspect most barrows probably die of abuse long before old age.
Find me Chillingtons at £20 and I'll buy three, they are £60 last I saw for sale.Cheapy £20 metal chillingtons work well for me
Chillington galvanised?So,after some 30yrs mines dues for the dump,you've serve me well but its bye bye
Right then,does one stick to the old metal bucket as i've grown to use or whats these new tuff as **** polyplastic whatever,ones like?
Remember,its to carry everything known to mankind(even the shopping from car to back door),have concrete etc knocked up in it,oh and to be thrown around and live outside for 1000's of yrs to come
Pneumatic wheel is a must
Your views please
Cheers
