britishmonkey
New Member
Iv bought a old trailer which i am in the process of sorting out but i have issues with the wheel bearing in one hub and wondered if anybody could help.
The outer bearing collapsed in hub 1 on the trailer. I orded in a new bearing L4469. And race l4410. However iv noticed when i put in the new race it sat too far into the hub therefore when i put the bearing in and tightned it up the drum was still loose on the hub.
I took off drums 2,3 & 4 checked the bearing numbers and were all the same as above. I cleaned them all up and looking inside were the bearibg race seats there is a thickness of around 8mm. On drum 1 the seat is only around 2mm.am i missing some type of washer or spacer or is it the wrong drum? All 4 drums are marked BBTF
Anybody have any idea what the make of tbe units are? The pcd is 140mm bore diameter is 95mm
Thanks for your help.
