3 Ducks
The problem with large single phase machines is the do not work well on low amps, because the transformer and rectifier is bulit to run at say 200A I have found when you switch them down they do not weld as well as a 180A single phase machine that has been built to work on thin plate, I would buy a single phase mig 240V 13A for up to 6mm then I would get a single phase 160A inverter for the heavy plate work, you can run a 4mm rod on a 160A inverter and take on site no problem
That is what I will do ! Thankyou for taking the time to reply..
Regards Ray
