Have used something similar in the dim past called a spherometer. Used to measure the curvature of a surface.
It's a 'Lens Clock' apparently
Well spotted - a quick squirt of WD40 and it is back on zero. The bezel doesn't turn or anything like on a dti.The one in the link shows 20 (not sure if it is plus or minus 20) in its relaxed state. Fizzy's one shows -1. Could his one be gummed up?
I am guessing zero is with all three points co-linear.
The German one increases anticlockwise; the linked one increases clockwise.
Perhaps I could turn it into the worlds most useless watch
Yes anti clockwise!Yes, zero should be with the probe and points against a flat surface. If there is any adjustment, it would be to set this contition, I think.
I think the sign convention *should* be +ve for a convex face. If so, the needle on Fizzy's will turn anticlockwise as the plunger goes in. (I could easily be wrong though.)
If you applied it to an ISO mugforscale, does it give a meaningful result?
You could use it to measure how much air you put into a balloon...It might have an engineering use. Look at 'radius of curvature' in the Wiki page:
Lens clock - Wikipedia
en.wikipedia.org
Definitely!This place never ceases to amaze me, with the range and depth of knowledge available.![]()
I will try it on one filled with hydrogen - using a candle to see by of courseYou could use it to measure how much air you put into a balloon...
