ned
- Eire
hello all
I have an ifl i-tech 170 mig inverter welder, and id like to do some aluminium mig welding with it. I want to weld some alu channel, seen in pic.
I got a quote locally of 200 euros to weld it.
If i buy the gas and other bits to do it myself ill prob spend around the same amount and acquire a new skill, so it seems like a way to go.
So what I'd like to know is, what size wire to go for, and following that, what sizes for the following items:
• teflon liner (seems like there is only 1 size anyway)
• torch tips
• knurled wire feed roller
I have a spare euro torch that i can sacrifice. I've never taken one apart, but my plan is to shorten it, if that is possible, so that the wire feed has an easier job.
___________________________________________________________
the only knurled roller I can find is the one in this ad, which is 1.2mm
http://www.ebay.co.uk/itm/MIG-WELDE...-ARC-LINCOLN-BESTER-NEWARC-ETC-/121673918216?
Seems like that will be a good fit for this welding wire -
http://www.wholesaleweldingsupplies.ie/index.php?route=product/product&path=37_96&product_id=1282
It seems very big though? ...1.2mm.... I've been using 0.8 wire up to now
.....what size tip should i get.... I recall reading somewhere to get a slightly larger tip than is needed
Any advice or opinions welcomed,
regards,
ned .
• torch tips
regards,
ned .
