i need to install a few gates and posts around the field, ideally i would like to concrete in a load of 4"x4" steel posts then go round and weld the hinges on and hang the gates once they are set, ive got an Rtec 181 which runs happily enough through a 13amp fuse in a domestic plug/socket in the workshop i would like to run this off a generator on the back of a trailer that i can drag around the field , but what size do i need in kva i guess ? in the dim and distant past i had a murex set and it never liked running off a generator what ever the size i dont mind if its overly large as it stops anyone walking off with it at what should i be looking ? thank you
