From your photo they look like UNC which would tie up with the head size. Is there a shallow recess in top of the head?
AFAIK imperial nuts and bolts have heads that may be very close to metric sizes but would probably have a correct imperial spanner often marked with the bolt thread size ,ie 1/4 ,5/16 whit, across the flat sizes often given numbers ie 75 af is 3/4 inch ,also imperial sizes often include spanners sized in 32nds of an inch,when I was landrovering I searched for these odd sizes in boot sales etc
Whitworth and ANC threads have included thread angle of 55 deg unified threads have 60 deg thread angles some Whitworth threads will fit unified coarse if the tpi is the same,
The Royal family have imperial nuts
Chris
Yup , gonna go and buy a yard of 50 x 25 mm timber, and have 568 cl of ale , oh and a gallon of fuel, so I can work out mpg on my 2000 cc diesel engined car,it is rated at 90 horse power, does this mean my grocer won't get prosecuted for selling me a pound of tomatoes?, would have quoted you roan but dunno how yet,
Chris
Ta!Just click 'Reply' at the bottom right of their post, then type your message underneath the text which appears in the box you write in.
Metric bolts have the tensile strength in numbers, such as 8.8, 12.9 etc. Imperial stuff has a domed recess and three, five etc lines for tensile strength.
I was not able to test for ANC or UNC due to the absence of gauges on the thread gauge set I bought. I suppose to categorically exclude ANC I should buy more gauges?
