Hi All, I'm about to try welding aluminium for the first time. I need to weld 3 mm aluminium tube into caps I have turned with 3 mm walls (6082 T6), see pic. I'm after some advice on the following:
Thanks for any advice.
- Electrode type, should this be pure tungsten?
- Electrode size?
- Cup size?
- Do I need to buy new cup, collet and collet body and not use the ones I've used with steel?
- Welding rod size?
- Welding rod material?
- Argon flow rate?
- Amps setting?
