I have an old suzuki jimny that needs a bit welding. Quite thin panels.
What would you guys recommend I don't want to spend a load and can't see myself using it for much more than this Jimny maybe use to weld a nut of a snapped off stud at some point.
Is this a good machine, I want gasless I know results won't be as good but will do for me
dirtyprotools.co.uk
Professional 140A Gasless MIG, TIG and MMA 3-in-1 Welder Non Live Torch model 230V No Gas with Mask & Welding Wire
This model has 3 functions, working as MIG, TIG and MMA welding PRODUCT NAME; * 140 Welder 140A With Accessories. For greater welding control the wire is only live when trigger is used Cheaper models have permanent live feed wire making it difficult to set the wire in the correct starting...
