Memmeddu
- Italia Sardegna
Hi everyone, hope you are doing well.
So we are going through many jobs at machine shop, and those belonging from the drilling companies are a little a PITA.
Especially because you can't really go through carbide...
The use hallen screws, drilled through and then covered with carbide.
The main problem is when those get stubborn and we can really do anything to free hem up loose.
We practically just pierce a 100mm steel plate with a combination torch and we ( me cause I'm the torch guy) get all sorts burns everywhere on the body.
Since those customer are supposed to work around for about 4 years, I'm thinking about making my own thermal lance cause my boss isn't going to even think to buy one.
I can't find an used one myself and I'll never buy a valve and a collet chuck for more than 1000 euro if lucky.
So here it comes my project in my mind.
An ER type collet chuck from AliExpress with suitable collets so 6 and 8mm.
Machine a flat surface to put a rubber or silicone gasket.
Drilled through, tapped at M8 to fit a terminal for electric connection.
Then a perpendicular hole tapped at 3/8 BSPT to fit a flashback arrestor.
Till here should be an easy task.
Problem comes now cause I don't know where to find a push button valve suitable for the application.
Oxygen compatibility is a concern but honestly I work in a machine shop everything is covered by oil and grease cutting torches included.
A potable water valve should be able to get the job done.
I've seen people (arcair included) using pressure washers valves, or even blow guns for homemade solutions.
The next option would be machine my own or switch from the "Broko BR22" design to a more simple ball valve straight oxygen lance handle.
Being a small lance 6Bar of pressure would be just fine 8 at the most.
We run our torches at about the same pressure or even more and again they are very dirty
