This is a very common type of vac used by asbestos surveyors to clean up small amounts of debris when taking samples.
should be fitted with a HEPA filter and appropriate bag.
that switch is a shake down for the filter. They are almost always disabled
Worth using a cyclone between this and the tool. Have a look on YouTubeAha, thanks Parm. I was hoping it might be something like that, would be nice if it worked but perhaps this one has been disabled? It doesn’t appear to make contact with anything on the other side but has some sort of spring detent.
Here’s a better picture:
It seems to be a good one from the scant information I can find online but can’t find replacement filters. It was almost free to me, nice and robust. Hoping to use it with the track saw and router - it’s got a hell of a suck on it, will get some instruments on it when back at work and find out how much.
.what ts did you go for in the end
Email the company they will more then likely send you a manual via emailAha, thanks Parm. I was hoping it might be something like that, would be nice if it worked but perhaps this one has been disabled? It doesn’t appear to make contact with anything on the other side but has some sort of spring detent.
It’s amazing how much useless info we store that some one else needsGlad you knew - because I did not have a clue![]()
Prefer there rails over dewalts. Much closer to the fes.
What we need is a forum Drone...so we can swap and send things free of charge.It’s amazing how much useless info we store that some one else needs
