I've never hard wired a welder, just use a 16 amp plug if it doesn't recommend a 13amp plugHey i have a clarke 145 en machine and i have no clue what i need to wire it in to the mains . it has to be hard wired in but i have no idea what it needs any help would be great thanks
Hey thanks the bloke also said i need to plug it into a cooker socket is that needed or can i get away with a normal socket its a bit confusingI've never hard wired a welder, just use a 16 amp plug if it doesn't recommend a 13amp plug
@brightspark is the best person to ask, but I just wired the socket to a 16amp fuse/circuit breaker. I think a cooker socket is something like 30 amp, but our cookers just got a 3pin plug on it.Hey thanks the bloke also said i need to plug it into a cooker socket is that needed or can i get away with a normal socket its a bit confusing
Any images of the connections you need to wire to?Hey i have a clarke 145 en machine and i have no clue what i need to wire it in to the mains . it has to be hard wired in but i have no idea what it needs any help would be great thanks
!3 amp plug is fine, 32 amp mcb, cooker circuits require 45/50 amp mcbs. 16 amp round pin plugs ( 32 amp mcb )are more for the professional end of the market, so I use one for my plasma cutter.
Bert
