Depends on the motor. I have 5hp on a 15A breaker. Has never tripped. 5hp=about 10A running. There may be startup issues, but I have a very fast breaker.
A 2-stage will use less HP. Mine is 5HP/12CFM @ 90PSI, I have seen 3HP 2-stage with the same specs. 2-stage also tends to be quieter.
You can get 2 stage 4hp compressors, but you only seem to gain a couple of CFM for the difference, and a 4hp motor is a fair strain on a 240v supply, its a 3000watt motor which could pull up to 12kw on starting
one thing know one has mentioned is GO FOR A BELT DRIVEN compressor unless you want to p**s off everyone from the noise direct drive make and end up with beeding ears (a bit over the top)![]()
Yes! My last compressor was 3.5HP, direct-drive and was deafening. I upgraded to a 5HP, belt-driven and it is probably 1/3 as loud.one thing know one has mentioned is GO FOR A BELT DRIVEN compressor unless you want to p**s off everyone from the noise direct drive make and end up with beeding ears (a bit over the top)![]()
