the process is called .. clicking ,, they use it in shoe making and saddle work.If you made up steel rule dies (I forget the proper name) you can cut leather, paper or whatever but in your case, I’m not sure that would be useful!
BFO press for laminating wood?
Donor for power pack and other shiney bits would be the case if I were offered it
offer in buy or scrap value ?If you made up steel rule dies (I forget the proper name) you can cut leather, paper or whatever but in your case, I’m not sure that would be useful!
It’s definitely a squashing machine of some sort, the place it came from used it to compress carbon fibre molds, there are four very hefty looking rams on all four corners of those thick steel plates.
Bob
I remember doing a job at Lockheed back in the 1970's on a press like the one in the Hugh Smith video, where a 1000 ton rubber pad press had broken one of the upright bolts. We had to remove part of the roof so a crane could lift the bolt out and place it on a flatbed truck to ship back to east where there was a lathe big enough to turn down the ends to a point, and then machine weld the two parts back together. It also took several of us pushing & pulling on about a ten foot cheater bar attached to the wrench to loosen up the nut, which was about 30" inches across the flats in order to remove the broken part near the foot of the machine. Two months later we had to take off the section of roof to crane the repaired bolt back in.
Looks like it.Is it just me ,or does it look like the motor and pump have already been removed from the tank?
