Ross365
- UK
Well, no sooner had I put my Mr Smug outfit back in the wardrobe, having installed my new TRV, than I noticed drips falling from an overflow.
No surprise that it's the header tank for the heating. Now I've been in this house the best part of 30 years, but don't recall that needing attention previously and I was shocked when I lifted the lid off the tank. There's what is almost certainly a nice 1960's ballcock and the valve is encrusted with scale (like something raised from the Titanic) to the point you can barely tell what starts where on the fitting.
Long story short, the tank is actually fed by a 5/8th inch (~16mm) pipe going in to some ancient bulkhead fitting and having distinctly unfamiliar fitting inside the tank. First time I've found 5/8th pipe in the house! The design of the valve seat was something entirely new to me. Subsequent investigation that this would be a job for my handy chem-lab cork hole-borers; a small rubber disc cut with No7 borer doing nicely (~6mm). So I took it to bits and threw the whole thing in the ultrasonic cleaner, first with alkaline cleaner and then with citric acid solution and eventually got it looking like a functioning device. Then smeared it all over with silicone grease.
I see that somebody has started a charity aimed specifically at pensioners who need plumbers - I really must get their number
and had to use metric/ imperial adapters on the pipes, earlier this year.
