Hi im going to be welding 1mm maybe 1.5mm mild sheet steel, car panels, wat is the best quality wire for this job, I dont want cheap crappy wire that will ruin my welds, ill be using argon/co2 mix, thanks
i've used lincoln in my welder and just couldn't get on with it sounding like a machine gun when the arc started then settling down to weld great until the next start now i'm not blaming the wire by any means more the machine (SIP) but i changed to murex bostrand .6 and find it works fantastic every time. just wondering if different wires work better than others in certain machines??
I, like cumbriasteve, have found the Lincoln wire to be very good, even in a SIP, which, as many already know, can be quite touchy welders!
All the Best,
CJ
