W.olly
- Radcliffe, Manchester
Hi y`all, i am wanting another Thermal Arc 181i but also wanting to weld up Steel box of 8-10mm thick wall thickness and double weld, inner and outer.
Problem is that i only have single Phase on 16amp for the 181i, idea is to stick weld the outer and then mig the inner as this will be easier to get into also as the box will only be 350mm x 200mm cross and 450mm high.
Good or bad?
Good or bad?
