- UK
Evening. Got me serious head on, so bear with me please.
With a nod towards sloping off from where i am working now and truly running my own business, i am reviewing the opportunities to formalise my welding training. I have read the posts on here as well as err... the other welding forums, but could still do with a bit of direction from anyone who is in the know. (Simondrains seems to know a thing or two about this)
If/when i go on my own i need to make the business skill base as large as possible, and as such need to be able to offer welding on pressure vessels, as well as structural welding etc. - not just limited to gates and sticking peoples cars back together.
In an ideal world, i would like to sit whatever tests are needed whilst i am still where i am, so when i go off on my own i am ready to get going, not trying to get a specific certification once the job has come through the door. This would also suit from a financial viewpoint.
So, i am looking at what training is available, and which would be most suitable. I know for pressure vessel welding, you need to pass a coding test which is specific to the method of welding and position - each seems to be very specific and lasts only three years - would you need to pass a coding for each, and can i take the coding with me, or does it refer just to the job?
Similarly, for structural welding, do i personally pass the test to allow me to do this work generally, or is it specific to the job in hand.
The following is an extract from one of the websites i have been viewing and seems about the most straightforward summary, but still does not answer all my questions. Then again, it could be me being fick.
"There are two basic levels of welder certification, often referred to as Class 1 and Class 2.
Class 1 is the international coding standard for pressure vessels and pipe work e.g. ASME 1X and BSEN ISO 15614-1 2004/BSEN 287. The completed weld samples are usually subject to x-ray/ultrasonic examination and destructive testing if required by the welding code/standard.
Welding procedure and welder qualification tests are available to BSEN ISO 15614-1 2004/BSEN 287 and ASME 1X. These are witnessed by an independent inspecting authority (Lloyds Register or Zurich) arranged by Wakefield Skillcentre Ltd.
Class 2 welding or BS 4872 standard applies to a wide range of general fabrication work when an approved welding procedure test is not required. Welding tests are carried out in accordance with written instructions and the weld samples are subject to visual and destructive testing.
Welder qualification to BS 4872 standard are witnessed and certified by XYZ Skill Centre."
Much abliged. Paul sits back and waits for all the helpful responses........
