carlos420uk
In the garage....
Ok after a few months of regular Tig practise I now feel confident enough to start a little project.
I am going to have a go at making a 4 cylinder turbo manifold. I intend to use 1.5" schedule 10s or 40s butt weld fittings and straight pipe in 304L (got a few pieces on the way to have a play with before I decide which to go for) and am looking for a bit of input on the best way to go about butt welding these pieces together.
I know that I will need to back purge all joints, but what about just tacking up? Do I still need to be purging then or should I be trying to avoid full penetration when tacking?
As for the actual welding procedure, what is the best method for maximum penetration / strength, as in how many amps, number of pasess, tungsten and filler size? I have read that you can just fuse a root in and then use filler for a cover pass. Others are saying use filler for both, and some say that a single pass with enough filler will be fine
I was thinking 2.4 Thor. Tungsten, 1.6 filler, no.8 gas lens and around 120amps adjusted on the pedal? Would pulse be of any use also?
Lastly I have been told that 308L filler is fine to use for joining the 304L, is that correct?
Any advise on this would be great,
Cheers
Cheers
Forgot to take pics after the filler pass, but will post them later.
