God mode restorations
- uk colchester
Morning all...dose weld through primer actually work.....or is it a case of it sounds good on the can but ain't worth a wristy ..
I see your point...But ask yourself is their any point when you will have to re-prime the areas welded? I should always try and remove such things from the area of a weld prior to lighting up personally as the least worse thing is more smoke
One of the fittings was attached to a pole and the fixing screw wouldn't come undone - snapped an Allen key trying ! Got propane torch out and heated it as hot as possible but screw still firm however the paint didn't even discolour, bubble or was affected in any way.
