super noob
Having some trouble getting enough current to run the stick welder at 110A right now as I'm not able to install the big 80A circuit for the TIG for a bit so left with a 32A and a 16A set up
It seems to trip the breaker (got a freezer on the same circuit so always on) so thinking if I was to weld on the 32A circuit in order to reduce current draw I could use some 2.5's instead of the 3.2 6013's but would they be suitable for 1/4" mild steel sheet ?
My thinking is instead of trying to put out 110 to 120A to weld with the 6013's I could draw around half to two thirds that with 2.5s ?
Anyone know if they'd be just as good for the 1/4" steel I weld ?
I'm using an old oil cooled welder so no idea what its drawing but I found it was made in Sheffield by something like welding electrodes sheffield (cant remember now)
not allowed to do it myself as its a business so will no doubt cost a bit but hey ho
yeh think it's time to think about a 32 amp supply - but that might be quite so easy /cheap depending on your current setup.
