Hello, can anyone give me some advice on if its possible to weld copper beads onto copper pipe and also the quickest/easiest way to achieve it?
The pipes will vary from 100mm to 22mm. I need to completely cover the pipes in weld to achieve a 'bark' effect as they will be used as part of a copper tree water feature.
I have very little experience welding but do actually own a small stick welder which i have used to blob together various bits in my workshop. So please go easy on me if I ask silly questions. I was wondering if it was possible to use a mig welder with copper wire? Or maybe you can get copper stick rods? Both materials are the same so should stick together. Problems I foresee are the wall thickness of the tube which is only 1mm or 2mm at best on the larger pipe.
Thanks in advance if you can help.
Cheers
Lee
Cheers
Lee
