Welding chain and removing a valve
  1. Lazurus
    Lazurus Member
    874
    Norfolk uk
    As the title says I would like to get some chain to make decorative legs on small tables, and now a wood burner from a 13kg gas bottle.
    So, any types of chain to avoid, or hints for a newbie MIG user. And some advice on removing the LPG gas valve is it a simple unscrew on a R.H thread or is their some dark magic needed?
    Cheers
  2. slim_boy_fat
    slim_boy_fat Forum Supporter
    Iirc [:ashamed:] the regulator is L/H thread
    The_Yellow_Ardvark and Lazurus like this.
  3. pedrobedro
    pedrobedro Man at Matalan
    10,461
    CX Derbyshire
    The valve into the gas cylinder is a normal thread. I lay them on their side and sit on them then beat them round with a drift and hammer. Regulators for propane fuel gas are left hand thread but not the valve. :)
  4. Ashley Burton
    Ashley Burton Member
    4,308
    Northamptonhire
    Yeah I beat the living daylights out of the one I had to remove the valve from the bottle!
  5. anto44
    anto44 Member
    1,374
    ireland
    Handy tip for using chain like that is to hook one end of the chain onto something solid and hook a ratchet strap or something similar to the other end of the chain and attach that to something else and pull the chain as tight as you can then when you weld it you'll have a perfect straight piece of chain.
  6. anto44
    anto44 Member
    1,374
    ireland
    Something like this
    stuvy, JEZGUZ, Lazurus and 3 others like this.
  7. slim_boy_fat
    That's probably what I was thinking about. :ashamed: As you were, move along, nothing to see here......:laughing:
    pedrobedro and Lazurus like this.
  8. brightspark
    brightspark Member
    30,475
    yarm stockton on tees
    just whack the side of the valve with a 2. 1/2lb hammer 3 or 4 times and it will come out
  9. outofthefire
    outofthefire Member
    2,308
    Leeds
    Try and find old ungalved, unpainted chain. and cut the valve guard off the gas bottle it's easier to get at the valve without that in the way.
    brightspark likes this.
  10. Bobtail4x4 Member
    737
    yorkshire
    or lay it in a length of angle,
    brightspark and slim_boy_fat like this.
Advertisements
