ghostdancing
- italy
while i'm waiting for a gas bottle,i'm preparing the welding bench, (it's made of steel): do i have to connect it to the ground (i mean the earth dispersion wire of the electric system)? if yes, when i'll clamp the positive from the welder machine to the bench all the metal in the shed (lathe, lathe bench, press drill, carcass of the welder, air compressor) will be part of the arc circuit..is this correct?
in the (small) room there are some metallic objects that will be not grounded (argon bottle, a pair of carts with a car motor\motorbike frame on)
will my electronic devices (computer, wifi router) be safe from HF interference?
i just checked the earth circuit and planted a proper ground dispersion bar in the garden
