The main RCD switch says 240v-50Hz RCCB 80A 30MAwhat breaker an rcd or the minature breaker and what amperage and type is it .standard are b type domestic
On average, how many Amps are you running the welder at when it trips? What thickness are you welding, and does the problem happen in both MIG and Arc modes?For some reason my welder keeps tripping the breaker in the garage I've used it else where and never had a problem but for some reason it's started tripping the garage every 5 - 10 mins has anyone any idea how I can stop this
TUNE!Am I the only one who read the thread title and thought of this:
).no way using a d type. and as for the supply he said its rcd protected . at minimum it will be 2.5 cable and can handle up to 25 amps. as i said in an earlier post maximum 20 amp mcb and that leaves a good margine for safety . mcb will not hold the full load amps that they state they are rated atRealistically, us just saying uprate to a bigger/slower MCB probably isn't good advice with what we know - I'd be comfortable moving to a different MCB if it was my wiring where I know what the cable spec and circuits are - we don't really know enough of the supply to just say uprate it - it may be that the 16B is there because that's the best the cabling can handle.
I've actually changed my mind on this since since I said just bung in a type C or a D - it's not really a good idea until you have full details just to modify
