slim_boy_fat
- Scottish Highlands
I'm about to install an outside LED floodlight and it came with a ridiculously short power cable [240V supply]. The unit is sealed so I can't replace the cable all the way back to the internal connections.
Does anyone have any experience of this type of connector before I push the button? I don't want to be drilling more holes in the wall than I have to - also looking for ease of connecting, with my luck one of the tiny screws would end up on the ground......
CLICK HERE
CLICK HERE
I soldered and heat-shrinked (adhesive) mine to extend it into house loft and termination from there using standard 5 amp junction box. I stagger the lengths of the 3 cores and shrink them. Then a shrink over that. One thing I started doing after 50 odd years is not twisting the strands and laying them together. But instead keeping the strands straight and pushing the wires into each other, squeeze to flatten then solder. Makes a neat joint and holds them together prior to soldering. Ironically the issue I had afterwards was water ingress into the 'weatherproof' lamp.
