mangocrazy
Italian V-twin nutjob
- Sheffield, UK
Is that direct from British Salt? And is it loose or in 25kg bags?£119 per Tonne from British salt
what softener did u go for anyway I forgot to ask?
me neither, is it a digital one?It's a Pentair 255.
Made in Italy!
Never heard of them.
Direct form British salt. Bulk tanker delivery its like table salt only bigger grains, you can buy salt tablets for water softening in 25Kg Bags but no idea how muchIs that direct from British Salt? And is it loose or in 25kg bags?
Never had issues with either, industry use bulk to a salt saturator tank if they have room as it eliminates manual handling of the 25Kg bagsits like corse sea salt aint it, the tablets are good too but they have more impurities in them to make them into tablets
no but the tablets can kill softners like kineticoNever had issues with either, industry use bulk to a salt saturator tank if they have room as it eliminates manual handling of the 25Kg bags
Yes unfortunately!we have one like that at work u set the regen days and the water hardness and the time you want it to regen. Are you on a water meter?
Considerably more expensive than £120 for a tonne! If I had the storage space I'd go for the bulk load, but it will have to be expensive bags.Direct form British salt. Bulk tanker delivery its like table salt only bigger grains, you can buy salt tablets for water softening in 25Kg Bags but no idea how much
in that case set the regen to the longest day setting you have, 5 or 7 days probably or your water bill will go up massivelyYes unfortunately!
when it does the regen the brine gets washed down through the resin filters and then goes down the drain!^
I've got no idea how they work!
I didn't know that they used more water though! How much do they use in a normal household?
I just turned up to the Wickes nearest my job but they are click and collect only I got talking to the guys having a fag break and they took my order and went off and got it all for me!
Best bit was when I asked how much?he said don't worry it's free!!!
4 cans of cold drinks went their way as a thanks.
The water is hard here, but not as hard as just down the rd. I fitted a unit with 2 opposing wound cables around the incoming supply. Plug it in and forget. It uses next to no leccy. Its been in 18yrs now. We still get a bit of scale but nothing like we used to.
