Didn't know such a thing existed , I want it for cleaning a diff and gearbox for rebuild , moons ago I used a wallpaper steamer , stuck the hose into a bucket with the bits in and steam heated the water and detergent , no longer have the steamer or a good area to do it , hence water soluble ,As above, Screwfix, but why does it have to be water-based? If you look for 'emulsifiable degreaser', you find solvent ones that do a really good job but wash off with water into the drain. They leave the parts slightly oily if you use plain, cold water, but a hot, soapy rinse afterwards will have them clean enough to flash rust.
Didn't know such a thing existed...
Not going to name a brand. Neat TFR and leave as long as possible to soak in, heat really helps so if your pressure washer is ok with hot water its worth connecting to that.
Bob
it will soften your paint mind its bloody strong undiluted , its meant to be used in hot water washers diluted down about 60 to oneit strips your skin and it peels off if u get it on your handsYep, TFR is very caustic generally, it's up there with drain cleaner - it damages paintwork and allsorts if you leave it on neat.
Surfex HD works great as a water based degreaser that's safe for most stuff.
only once stupidly did it with no gloves on neatJust a pain shoving the washing machine out of the way to connect the power washer to the un-used hot water supply . . . but it did make an excellent job of cleaning my hemi block and headsNot going to name a brand. Neat TFR and leave as long as possible to soak in, heat really helps so if your pressure washer is ok with hot water its worth connecting to that.
Bob
