chunkolini
celebrity artiste
- Swansea
Hi all
Wanted a gear lever for a motorbike. What bike? couldn't care less.
My Urinal (Ural/Dneprthingy) needs a gear lever.
A handsome kind of shed.
The original is the most stupid fitting I have ever seen.
it slides onto a 15mm OD splined bar, as is usual, then cunningly a nut goes onto the end of the spline and tightens the lever onto a shoulder on the end of the spindle. Eh? so no matter how tight you do it up the splines dont do much and get knackered.Also the previous owner has cut and welded the original in the most unimaginably stupid way so as to ruin it and probably the original spindle as well. Pillock. If I can find the energy I will post a photo.
So I am looking for a gear lever that has a slotted clamp, like they all used to have with a 15mm ID tightening onto a splined spindle. Dont care about what gauge the splines are. The splined bit is 15mm OD, and 6mm long, then there is another 10/12mm of spindle threaded to M10. Stupid, I can make some kind of brutal split collar thingy to go over the first half of the threaded bit.
The gear lever can be bent, ******ed or otherwise discombulated*.
All I need is the basics, ie the attachy end bit* to make my own Chunkular style lever. I fancy a hand on the hand of a recognisable arm.
One of you guys has a box of shagged gear levers.
Cheers all, Chunko'.
* Apologies for lapsing into technical jargon.
