Plate exchanger is easy to remove and re fit, new seals if you want to make sure but 99% of time old ones are re usable.
@earthman I do agree with what @eLuSiVeMiTe has said to you! Just got to suck it up & find another plumber that wants to do the job or as you've mentioned you get your hands dirty
Finding good trades men isn't an easy task, But when you do pay what they're worth & the job gets done
how old is the boiler
generaly after 9 years living on borrowed time
From baxi
2.21 Plate Heat Exchanger (Fig. 64)
1. Drain the primary circuit.
2. While supporting the heat exchanger undo the
screws securing it to the brass manifolds.
3. Withdraw the heat exchanger upwards and to
the left of the gas valve, taking care not to
damage any wires or controls.
Seals
4. There are four rubber seals between the
manifolds and heat exchanger which may need
replacement.
5. Ease the seals out of the manifold. Replace
carefully, ensuring that the seal is inserted into
the manifold parallel and pushed fully in.
6. When fitting the new heat exchanger note that
the left hand location stud is offset towards the
centre more than the right hand one.
7. Reassemble in reverse order.
12.22 Diverter Valve Assembly
No the diverter valve is not included in that section, just caught that with copy n paste lol
If I recall from my Baxi, genuine exchanger seals were something horrific like £12 each - for glorified O-rings.
