V veesix Member Messages 68 Jun 4, 2021 #1 I need to replace a 1-1/2", 1/8 NPT vacuum gauge. Anyone know where I'd find one, preferably UK? I've had 2 from eBay (via China) so far that turned out to be 2" 1/4 BSP when they arrived. Cheers. edit: needs to have the port on the rear too!
rikrobson Member Messages 3,956 Location Perth, Scotland Jun 4, 2021 #2 can you not get a 1/8 ntp to 1/4 BSP adaptor?
zzr1200 Working at 650 ft on open steel work. Messages 6,784 Location Glapwell, Chesterfield, Derbyshire, UK Jun 4, 2021 #3 Try phoning "Flowfit"
Ross365 Member Messages 2,111 Location UK Jun 4, 2021 #4 Fluid Controls Ltd in Aldermaston is worth a try, but they mainly do pricey stainless stuff.
A Agroshield Member Messages 6,444 Jun 5, 2021 #5 https://www.mikrospin.co.uk/hydraul...tion-line-amffse/indicators/sofima-10s.p.aspx (correct dia, 1/8" BSP thread) https://www.airsupplies.co.uk/vacuum-gauges-centre-back-connection (correct dia, 1/8" BSP thread) http://modusgauges.com/Pressure-Vac...re-Back-Connection-Accuracy-2-5-/prod_14.html (correct dia. 1/8" BSP thread) Do you see a theme emerging here? US pipe threads are difficult to find in (or out of) Europe... Any NPT that are available seem to start at 1/4". https://www.vacuumgauge.co.uk/vacuum-absolute-gauges/small-diameter-vacuum-gauges/ (looks a possibility), see also Build a Standard Gauge - Leading UK Supplier of Pressure Gauges Our step-by-step ”build a gauge” facility is designed to help you select the most suitable instrument for your application. www.pressuregauge.co.uk A couple of US ones: Pardon Our Interruption... www.ebay.com https://www.productsforautomation.com/durachoice-pa158bv00-vacuum-gauge-112-0psi-p/pa158b-v00.ht
M MCKDAVID Member Messages 2,785 Location South West France Jun 5, 2021 #6 try your local refrigeration / air conditioning place, they'll have vacuum guages for the fridge pipework tests, they'll probably have what you need in stock.
V veesix Member Messages 68 Jun 5, 2021 #7 Thanks for the suggestions, I'll take a look. It's for one of these, so using an adapter to BSP would leave the gauge sitting proud: The gauge is available as a spare part, but with shipping and import duty it would cost as much as I paid for the entire thing.
