If it's just for general use then either....if you want cheap and good quality I've found the Halfords stuff is very good.I'd choose Draper over USPoo any time.
Where’s the quality,after a 30mm ratchet spanner without the switch lever,these two were the only branded ones,in the past ,I’ve found draper either average to very good
Ive been spannering all month , on lr rr of all things , lending a hand to a friend whos in bother at the moment ,, Ive broken two snap on sockets in the last two days , by hand no ugga duggas , both from the same set and neither had an excess of force on them , a 12 and a 15 , both six sided semi deeps ,, so nothings indestructible but the van is round tomorrow and both will be swapped out . Draper Experts good stuff , thirty years ago you used to get Indian Draper with stamped in branding , not so good , and Draper made in Japan with raised oval branding , and it was great stuff even back then. ,I have lots of Draper Expert and US Pro tools. Never had an issue. Albeit I have never broken a single socket or ratchet in my life as I care for my tools and have appropriate range for my needs. Eg 1 inch torque wreches for crank bolts etc VS putting poles over ratchets to give er wa.
