Ashley Burton
- Northamptonhire
Leave her outside?
If its a pig to operate when open you might get away with removing and lubrication but something is probably broken in the latch box so needs replacing...
it might just be the barrel lock if the door opens and closes ok. failing that more than likely the gearbox wants changing at real worst change the whole mechanism about 120 quid ish. simple enough to get out and do just remove the one lock screw pull it out then unscrew the rest and remove![]()
to get the barrel out take the one screw out holding it in . put the key in and slightly turn it and the barrel should just pull out easilyI’m off tomorrow so will give it a go
