You could got the same, cheaper from Screwfix or ADI.The favour I'm owed has resulted in two 7Ah Yuasa batteries ordered this morning from RS!
Thanks all.
Doubt Screwfix is cheaper than "Owed a favour" which I'm assuming means free
If the OP goes fir the same 7.0ah they have standard size terminals. It is an industry standard.
If you only want to power a router, why not fit just one battery if the old ones are in parallel.
I find the APC auto-charging and self-test routines are too stiff. I was able to trim the timings to once a blue moon and just kept a monitor on state of charge. As a result, my first APC batteries lasted nearly ten years..The APC Smart SMT UPS is a solid choice, but battery swaps can be a bit tricky. I’ve had success using quality third-party replacements as long as the voltage and Ah rating match the originals. Some aftermarket batteries last just as long for a fraction of the cost. If you go that route, make sure the connectors fit properly, and avoid anything with a poor track record for reliability.
I have a few APC SmartUPSs. The original batteries last a decade or more and so do the replacement APC batteries.I find the APC auto-charging and self-test routines are too stiff. I was able to trim the timings to once a blue moon and just kept a monitor on state of charge. As a result, my first APC batteries lasted nearly ten years..
My second set co-incided with the original software being impossible to operate with later OSs, so had to rely purely on manual, but the shutdown and timing could be used, without letting APC anwywhere near the charging, except initially.
Even so, a know good pair of third-party batteries lasted a mere two years and a third set, the same again.
Obviously the original APC-supplied batteries were v. good quality to last so long and the aftermarket ones not so good, but left to APCs care, the original pair wouldn't have lasted more than a couple of years, I'm in no doubt about that.
Availability and price.I've thought about using 3rd party batteries but can't think of a reason to.
Well, availability is just a mouse click away, so that's not a problem.Availability and price.
Here, APC will rook you blind for the APC sticker on a battery.
The first ones were Yuasa with an APC logo on them. Istr there were codes on the casings which gave the game away.Nothing special about the batteries, APC don’t make the cells.
Physically, there's nothing special about the batteries, there's no particular need to buy originals, in terms of a physical fit, they're standard dimensions and the harness is trivially easy to swap over.Well, availability is just a mouse click away, so that's not a problem.
I can't remember how much the replacement battery costs but they arrive with the correct connectors and there are no dimensional surprises. For a once a decade expense, why bother?
But of course, each to his own.
Jack
APC always had a reputation for running "hot" with their charging, there was also an issue in the firmware at one point which cooked batteries, which I think was resolved eventually.
The "official" batteries are just banks of standard SLA batteries with some wiring and connectors on the top.
I've changed plenty by just swapping out the batteries with a decent quality brand and transferring the proprietary wiring onto them.
If you stick to something decent like Yuasa you will get the same life for a fraction of the cost – can’t remember the actual price of the last one I did, but it was the sort of difference of say between £320 and £60 – well worth doing, put it that way.
Obviously on mission critical systems its worth going for the official ones, purely to cover your backside (although if it was mission critical, I wouldn’t be using APC in the first place to be honest).
But 99% of the time if you give the customer the choice they are going to go for the cheaper option.
On APC units they do a self test fortnightly by default, this is a short duration test that should have minimal impact on the cells.
No doubt the APC (Schneider) stuff is the best on the market, you won’t see anything else in big data centres, they go all the way up to about 4 megawatts in those.
