Ive borrowed the welder from a friend and its not a keeper if its at fault. Its a 90 amp welder which is quite old and hasnt been used for a while. My friend is a good welder who restored many cars and he said he struggled with it to .The first welds I did had zero penetration and couldnt even blow through 1.2 mm steel on maximum power(this was with the lead still wound and at full length) . I replaced the wire , liners , nozzle and shroud and gave it a good clean up . The above pictures are the results obviously front and back (now using the shortened lead) . These are on maximum and low switch settings .The problem Im having is when I tried spot welding, again I had little to no penetration. I havent welded for years and am open to any Help and criticism as if I can avoid buying a new welder the money can be spent elsewhere on my project.
thanks
James
