CompoSimmonite
- Werrington, Staffordshire Moorlands.
I've got an untraceable clunk on my car a 05 Smart Fortwo.
It doesn't seem to have a trigger and can happen on a glass smooth road yet hit a pot hole or speed hump where normally you'd expect such a clunk to occur and nothing
Braking or accelerating doesn't cause the clunk either.
The clunk has only recently started (within last 20 miles and rapidly got worse during that period) You can now physically slightly feel the clunk though the floor as well as hearing.
Braking, steering, ABS & handling all as normal. Rocking car when stationary doesn't generate the clunk.
I recently changed both the front wishbones and drop links. The bottom ball joints were still good and antiroll bar mounts sound. I'd previously changed front springs due to a (pot hole) break so know front shocks and upper mounts OK. I've been back under the car yesterday to double check and no loose bolts, broken bits, deteriorated parts, steering rack has no play, track rod ends alright so have eliminated front end as being the source of the clunk.
Checked rear (De-Dion) and springs / shocks good (both springs changed last year after another break), tie rod bushes unworn, no play in subframe mounts.
All 4 wheel bearings smooth and no play. Brakes not sticking.
It passed a MOT just a few hundred miles ago with no advisories other than part worn brake pads and surface rust on one brake pipe.
The only thing I can now think of is it could be a worn CV joint but no noticeable play when checked by hand. FWIW this is a rear engine and RWD car.
Could a CV joint create such a clunk that is impossible to generate "on cue" ?
Cheers.
Paul H
Braking or accelerating doesn't cause the clunk either.The clunk has only recently started (within last 20 miles and rapidly got worse during that period) You can now physically slightly feel the clunk though the floor as well as hearing.
Cheers.
Paul H
