Spark plug
- Durham, England
Yes, acquired another unknown measuring device of some sort, but what is it:
I have one identical to yours that i acquired a few years ago. A planimeter was often used by naval architects & yacht designers for measuring areas of irregular shapes for example when working out the displacement of a boat, the hull is divided into equally spaced vertical slices across the boat & the areas of each section below the waterline is measured you then use Simpsons rule to multiply the section areas together & the result is the volume of the hull below the waterline. This takes a long time & a lot of sums. I did this at college studying yacht design. Today i just press the design hydrostatics button on Delftship's toolbar & instantly all the calculations are done. In the old days this would have taken a weeks work!
