oceanobsession
hi me again. sorry about this but just bought a migatronic lte 200 tig. and im having trouble with a few setting. ive no manual for it can someone explain in simple terms please
1. Infinitely variable slope down
With this control knob you set the time during
which the set welding current will decay to the
minimum output of the machine. The time is
variable from 0-10 secs. Crater formation at
the end of a weld seam can be prevented by
using this contro
2.Infinitely variable post-weld gas flow
With this control knob the post-weld gas flow
is set between 2 and 20 secs.
3.Function switch
This switch is used for choosing between:
2-times:
You can TIG weld for as long as the torch is
held down, and from releasing of the button
until the slope down time has expired.
4-times:
Self hold. At the first pressure on torch the
button the welding starts. After this you can
let go of the button and the welding continues
until the second pressure, which activates the
slope down control making the welding current
slowly decay. When you let go of the button,
or when the slope down time has expired the
welding stops.
using this contro
3.Function switch
2-times:
4-times:
welding stops.
