I'm working on some CNC equipment that uses 35ET fuses to protect semi-conductors - the current (sic) issue manifests by blowing these fuses that are about £25 each from legitimate sources with VAT and carriage
uk.rs-online.com
So I don't want to pop too many fault finding (It's a power supply card in a Siemens 610 AC servo system, buried in a rack with numerous cables connected that are needed when testing:
These fuses trip in about 2mSec whereas DC breakers take about 20 mSec so I can't substitute one of those temporarily.
There are several others by other manufacturers but they also command stupid high prices - LSCB35, 35FRB, GSGB35
Anyone have any line on cheaper sources ? - Amazon has loads from China for about £8 each but theses ones blow fast as they have ultra high purity silver as the conductor and any fakes with copper in would be hard to eliminate
35ET | Eaton 35 A Bolted Tag Fuse 19 x 77 mm 690 V ac, 63.5 mm | RS
. So, I too am on the look out for a reliable product at a reasonable price.
. The rationale is that the fast 8A will be as fast or faster than the superfast 11A ??? I don't think I need to the sort of physical protection afforded by the original fuse. Or I could just use my old Avo8 ?
. I was initially licenced as G8, but in '73 the same call suffix came up on the G4 series and so I took the Morse test just to get that.
. I suspect that it's time-on-test at 10A is no more than 15 seconds, but I'm (currently) only working at 5A and below (investigating how my CTEK smart charger works).
