doubleboost
- Newcastle upon Tyne England
It is common practice to put snow (winter) tyres on to the drive axle only
This can lead to some interesting handling
I know this is the stated case.
As a bald tyre grips better than a treaded one on dry tarmac, tread doesn't really make any difference until the road is wet.
The shaving process cuts the tread from the tyre to provide a more stable tread base for increased performance on track. Traditionally tyres were buffed, but this introduced unwanted heat into the tyre carcass - so instead, we cut the tyres preventing heat build up which can compromise performance. Reducing tread depth in this way alleviates the tread blocks from 'squirming' under heavy cornering - thus giving better grip and feedback in dry conditions.
Just to put people straight a tyre with more tread gets hotter than one with less tread on a dry tarmac situation, because as the tread moves and squirms more the rubber gets hotter.
Tyres with less tread grip better and stop better, on dry or damp tarmac that is a fact, born out by major tyre manufacturers 'shaving' tyres ie taking tread OFF a standard road tyre usually down to 2mm to give better traction and handling for competition uses where they have to use a 'control ' standard road tyre that everyone in that championship has to use. where a tyre with low tread falls down is when the road has standing water.
I realize that this not good in a road situation where you have varying conditions and I would MUCH prefer to have new, rather than worn tyres on my vehicle.
But you cannot make a statement that a new tyre with loads of tread has more grip in all conditions because it in reality it hasnt.
On a hot summer day a tyre with minimal tread depth has more grip with the road.
http://www.pakwheels...rt-tire-shaving
at the moment my car is a nightmare on wet roads. the tyre tread seems to have dropped off very rapidly over the last 600 miles, it understeers a bit now where as it used to grip really well. they were only cheap tyres but still annoyed that they have worn to the limit after 5k miles, my father bought a set of similarly priced tyres for his jag about 9k miles ago and they still have over 2mm on the front
