themininut
Typical, when i need it... it doesn't work
SIP topmig 150 rubbish!
Wire feed works fine, power settings seem to do nothing at all. I can set it to power setting 6 and still not blow through .8mm steel! i'm using .6mm wire and trying to weld 3mm steel, its hardly penetrating at all. there is a slight difference between power setting 1 and 6 on .8 steel but not even enough to blow through!
The last time i used it was when i did my sills after the wire feed mod and it all worked fine then about 2 weeks ago.
Getting sick of it now.
M.
M.
